20 years agoQuestion about Data Cache and the compiler
Hi, I have the following situation in a Nios2 design: - the Nios executes some code - then the Nios stores all registers (also the control registers) onto the stack - the Nios is reset ...
20 years agoHi Danny, hi Scott,
thanks for your answers. I did what you suggested and read the according manual part very carefully again. While reading the chapter, I became aware of my mistake. I trashed some values because I saved the register values to the stack bypassing the cache. After (!) that, I flushed the cache... I fixed this error, tested it, and what should I say, it seems to work! Thanks a lot. Bye Bernd
