20 years agoQuestion about Data Cache and the compiler
Hi, I have the following situation in a Nios2 design: - the Nios executes some code - then the Nios stores all registers (also the control registers) onto the stack - the Nios is reset ...
20 years agoHi Bernd,
try to understand the datacache by reading chapter 7 of the following manual \altera\kits\nios2\documents\n2sw_nii5v2.pdf It tells you about bit 31 and datacache... I beleive that (but I'm not sure) only the -f version could have this sort of problem... Good luck. Cheers, Danny
