17 years agoquestion about __attribute__
There are two memory section in my Nios system, one external chip SDRAM and another onchip memory:a 16K byte ram which is generated by the SOPC tool. Our project need to put one function code in the ...
17 years agoHello,
How are your code sections being initialised? It may be that your on-chip memory has not been loaded. In my system I use flash to store the code images, which are then loaded into RAM by the bootloader at startup. My main code is loaded into an external RAM and I have an ISR which is loaded into on-chip RAM (specified using the __attribute__ keyword as you have described). I'm not 100% sure, but your setup may require you to re-compile your Quartus project (or update RAM contents at least) so that your on-chip RAM is initialised by the FPGA configuration. You should find that the IDE has created a file called onchip_mem.hex in your hardware folder which is used to set the initial contents of your on-chip RAM. I hope this helps. Cheers
