Question about a simple combinationnal custom instruction
I'm trying to build a very simple custom instruction based on this piece of code :
module or_ci ( ncs_test_dataa, ncs_test_datab, ncs_test_result ); input [31:0] ncs_test_dataa; input [31:0] ncs_test_datab; output [31:0] ncs_test_result; assign ncs_test_result = ncs_test_dataa | ncs_test_datab; endmodule I imported this file using Component Editor; it appears in the Customs Instructions of my processor but when I try to generate, i get that error message : Error: cpu_or_ci_inst_0 is not connected to any master. Please connect it to a master of type nios_custom_instruction. I couldn't find any information about the Custom Instruction Master interface and can't understand the utility of it as the custom instruction slave should always be connected to the processor. Any idea ?7 Replies
I've seen problems where adding and removing custom instructions causes them to get added multiple times (with an increasing numeric suffix each time).
The only way I could remove them was by hand editing the sopc file! - Altera_Forum
It seems you're right. I started again from scratch and it worked fine.
By the way, is there a way to edit a custom instruction ? (For a custom logic block, i can edit the component listed in the component library but for an instruction, i didn't find the way to do it). - Altera_Forum
I asked our Altera rep the same question ...
Q1: Reply: You may edit this component with the method below: [1] click File -> New Component in SOPC Builder tool [2] click File -> Open in Component Editor [3] select the tcl script file of the component - Altera_Forum
Thanks a lot for that quick answer.
Have a nice day - Altera_Forum
The combinational block is now fully functional. Now I'm trying to build a multicycle custom instruction which performs filtering in 4 clock cycles. The waveform of my component is available in the attached files.
I have also attached the configuration of the interface in component editor; I specified the number of clock cycles required. Here is my problem : when I go to the software part and I try my filter with that code : # include <system.h> # include <unistd.h> int main() { int i; int res=20; //int j; int tab[25]={256,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0}; for(i=0;i<25;i++) { res=ALT_CI_MY_FIR_CI_INST(tab[i]); printf("Iteration %d ; mem = %d \n",i,res); } return 0; } I get the following results : Iteration 0 ; mem = 0 Iteration 1 ; mem = -14 Iteration 2 ; mem = 10 Iteration 3 ; mem = 12 Iteration 4 ; mem = 16 Iteration 5 ; mem = 21 Iteration 6 ; mem = 25 Iteration 7 ; mem = 29 Iteration 8 ; mem = 32 Iteration 9 ; mem = 32 Iteration 10 ; mem = 32 Iteration 11 ; mem = 29 Iteration 12 ; mem = 25 Iteration 13 ; mem = 21 Iteration 14 ; mem = 16 Iteration 15 ; mem = 12 Iteration 16 ; mem = 10 Iteration 17 ; mem = -14 Iteration 18 ; mem = 0 Iteration 19 ; mem = 0 Iteration 20 ; mem = 0 Iteration 21 ; mem = 0 Iteration 22 ; mem = 0 Iteration 23 ; mem = 0 Iteration 24 ; mem = 0 These results are correct but there is a lag of one sample. Where could be the problem ? - Altera_Forum
You probably just need to set the "Clock Cycles" in component editor to 5. I've seen this setting trip up others (myself included). So if your logic has a pipeline of 4 cycles you want to use 5 in the GUI.
I tried to set the "Clock Cycles" in component editor to 5. Then i got my first result at the right time but then the next samples were "merged".
Then I tried to rebuild my design using falling edge instead of rising edge and now it works fine. Thanks to everyone!
