16 years agoqu(at)rtus II tool issues "always enabled IO buffer "
Hi all
I have a system build with SOPC builder it works fine and later i tried to add one more component to the SOPC design I generated the ptf file and I am running the qu(at)rtus II tool for generating the sof file But the qu(at)rtus II Tool issues the following error in Analysis and Synthesis Phase Error : incoming_tristate_bridge_data[0] has multiple drivers due to always enabled IO buffers I am unable to trace out the root of the problem please help me out regards M Kalyansrinivas2 Replies
Can you expand the error to see which signals are listed as driving "incoming_tristate_bridge_data[0]".
Jake - Altera_Forum
Hi Jake
I have set the exception address to sram and reset address to cfi_flash Error is issued on all the signals (1 to 32) of incoming_tristate_bridge (avalon) error : incoming_tristate_bridge_data[11] " has multiple drivers due to always enabled io buffer "sopc_top:s1|tristate_bridge_data[11]~119" incoming_tristate_bridge_data[27] " has multiple drivers due to always enabled io buffer "sopc_top:s1|tristate_bridge_data[27]~120" incoming_tristate_bridge_data[10] " has multiple drivers due to always enabled io buffer "sopc_top:s1|tristate_bridge_data[10]~121" In same manner all 32 signals of incoming_tristate_bridge_data are issued an error and also i observed that if i set the exception address to SDRAM and reset address to cfi_flash the same error is issued on SDRAM ios also saying that "has multiple drivers due to always enabled io buffers" I could'nt able to trace out the root of this error regards M Kalyan sriniavas
