12 years agoQuartusSetupWeb-14.0.0.200-linux.run: Syntax error: Unterminated quoted string
ubuntu 12.04
uname -r 3.8.0-29-generic wonder@wonder-VirtualBox:~/quartus$ ./setup.sh The Altera software you are installing is 64-bit software and will not work on the 32-bit platform on which it is being installed. Do you want to continue to install the software? (y/n): y ./setup.sh: line 79: /home/wonder/quartus/components/QuartusSetupWeb-14.0.0.200-linux.run: cannot execute binary file ./setup.sh: line 79: /home/wonder/quartus/components/QuartusSetupWeb-14.0.0.200-linux.run: Success wonder@wonder-VirtualBox:~/quartus$ sudo ./setup.sh The Altera software you are installing is 64-bit software and will not work on the 32-bit platform on which it is being installed. Do you want to continue to install the software? (y/n): y ./components/QuartusSetupWeb-14.0.0.200-linux.run: 2: ./components/QuartusSetupWeb-14.0.0.200-linux.run: Syntax error: Unterminated quoted stringNo RepliesBe the first to reply
