21 years agoQuartus Programmer Command-Line Problem
I try to configure the FPGA via NiosII Shell (NiosII 1.1) and Quartus Programmer using the following line: [SOPC Builder]$ quartus_pgm --cable="USB-Blaster [USB-0]" --mode=jtag --operation=p;test.pof The line looks correct for me but I get an error message: Error: Programming option string "p" is illegal. Refer to --help for legal programming option formats. Any idea, why the option p for programming is wrong?!?!?!? Thanks, damc4 Replies
try this:
Nios-sof --cable='USB-Blaster [USB-0]' <path and file name you want to download> Make sure to use forward slashes for your path and file name. This will in turn make a call to the Quartus programmer, but make sure you are programming the .sof and not the .pof file. - Altera_Forum
Thanks BadOmen,
didn't knew nios-sof. Damc - Altera_Forum
You're welcome.
I think that command is left over from the Nios I days (otherwise it would be called Nios2-sof). - Altera_Forum
Using nios-sof is often easier.
But just for reference, I think your problem with the command line is that you put a semicolon into the arguments. Under shells such as bash this is a command separator. If you escape the semicolon with \ or put quotes around that argument then it should work.
