Kevin26
2 years agoQuartus Prime Lite 23.1 RiscFree NIOS V Debugger Issue
I upgraded my Quartus Prime Lite version from 22.1 to 23.1 and I am now having a problem with the RiscFree NIOS V debugger configuration not detecting the NIOS V core. I found a knowledge base articl...
Jeet14
2 years agoHi,
please update on that you are able to program .sof, and run from RiscFree Debugger and also check on the selected correct cable and see if the Nios V is visible before running Debug:
Tiwari
