19 years agoQuartus II & SOPC builder compilation issues
Hi Friends,
I am using QuartusII v6.0 with network floating license accessed via LM_LICENSE_FILE set to port@host and having issues in generating & compiling NiosII processor system in SOPC builder & QuartusII. Following are the messages: In SOPC Builder -------------------# 2006.11.18 08:55:07 (*) Running Generator Program for cpu_0# 2006.11.18 08:55:07 (*) IP functional simulation model enabled: Uncheck System Generation Simulation box for faster generation if HDL Simulation not required.# 2006.11.18 08:55:14 (*) Checking for plaintext license.# 2006.11.18 08:55:16 (*) Plaintext license not found.# 2006.11.18 08:55:16 (*) Checking for encrypted license (non-evaluation).# 2006.11.18 08:55:17 (*) Encrypted license not found. Defaulting to OCP evaluation license (produces a time-limited SOF)# 2006.11.18 08:55:39 (*) Creating encrypted HDL In Quartus II --------------- “Error: Can't generate netlist output files because the file "C:/altera/projects/Niosii_custom/cpu_0.vhd" is an OpenCore Plus time-limited file" Please advise how to correct above errors. Thanks -braj1 Reply
This seems like a license setup problem. Go to the License Setup screend (in Tools menu) and make sure you have "Nios II Embedded Processor Encrypted Output (00A2)" listed. If not, check your license files.
Avishay
