21 years agoQuartus-II - Slow Slew Rate
I see there is a global "slow slew rate" option. Is it possible to turn it on for individual pins, using Tcl scripting? If so, how? If not, I guess I could turn it on globally; how much w...
21 years agoHi Jason,
You can do this in Quartus with the assignment editor: Assignments->Assignment Editor menu item Category: Logic Options: I/O Timing Then: "To" column: select the pin (you can do this via Node Finder) "Assignment Name" column: Slow Slew Rate Regards, --Scott
