11 years agoQuartus fitter taking 2+ hours for NIOS design
Hello, I am attempting to setup a NIOS on a Cyclone V SOC and my compilation times are right around 2 hours total. The fitter gets stuck at 35% for most of this time. The interesting thin...
11 years ago --- Quote Start --- What's the specs on the different machines? It could be you are swapping on your work machine because it doesn't have enough memory. I would also delete the db and incremental_db directories and try again. I've had problems in the past where it's fighting something based on an old incremental design. Pete --- Quote End --- I ended up finding out that windows was running two instances of Quartus even though only one was open and available to me. I found this in the task managers process list. Once I killed all processes and re-opened Quartus, I built with no problems. Thanks
