15 years agoQuartus "export: 137 ... bad variable name" error
When launching Quartus 10.0sp1 on ubuntu 32bit, i get the following error: /opt/altera/10.0sp1/quartus/bin$ ./quartus export: 137: 2000.00: bad variable name At first the quartus worked ...
12 years ago[SOLVED]: Here is how I did it.
Assume I have my installer at "/media/data/Archives/Gadgets-Apps/de0-nano-fpga-kit/design-suite/autorun" in my Ubuntu 14.04 64-bit system. First issue I faced: libz.so.1 not found. Run the following command to include the mentioned path to library path, which should fix this issue. # export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/media/data/Archives/Gadgets-Apps/de0-nano-fpga-kit/design-suite/autorun Second issue is the one this thread is talking about: " Quartus "export: 137 ... bad variable name" error" It is because of dash as default shell than bash. The following commands should fix it in Ubuntu 14.04. $ sudo update-alternatives --install /bin/sh sh /bin/bash 100 $ sudo update-alternatives --install /bin/sh sh /bin/dash 200 $ sudo update-alternatives --config sh While the above command prompts for default shell, select bash as default one. Then run the installer:# cd /media/data/Archives/Gadgets-Apps/de0-nano-fpga-kit/design-suite/autorun# ./autorun This should get it done!
