16 years agoQuartus 9.1 SP2 WARNING!!!!!
I've opened up an SR for this, but in the meantime, don't install SP2 if you need to use the flash programmer to program an EPCS with or without NIOS. This was specifically on a cyclone II, but it pr...
15 years ago --- Quote Start --- I found out this is not my problem, but here is the download for patch 2.46 that I tracked down. I can't post links yet so Google: "Why does an Active Serial configuration failure occur for Cyclone II devices when using a compressed programming file?" John --- Quote End --- Thank you so much John! I was searching for the linux patch so long and couldn't find it.
