16 years agoQuartus 9.1 SP2 WARNING!!!!!
I've opened up an SR for this, but in the meantime, don't install SP2 if you need to use the flash programmer to program an EPCS with or without NIOS. This was specifically on a cyclone II, but it pr...
16 years agoA quick update just so this stuff can be found by others: patch 2.46 does fix my issue as expected. However, no linux version of patch 2.46 is available according to the response I got from support.
Quartus 9.0 also works for me. I tried 9.1sp1 and it did not work for an unrelated reason (sof2flash runs 'quartus_cpf --device=EPCS128', which dies with a stack trace). I did not try versions earlier than 9.0 because I need Nios MMU support for this design. Edit 07/22/10: Altera now has a Linux version of Patch 2.46 available and I can confirm that it works.
