16 years agoQuartus 9.1 SP2 WARNING!!!!!
I've opened up an SR for this, but in the meantime, don't install SP2 if you need to use the flash programmer to program an EPCS with or without NIOS. This was specifically on a cyclone II, but it pr...
16 years agoThis is why it is usually better to only upgrade if there is a feature you absolutely need in the new version... And this includes service packs.
If it ain't broken, don't fix it, 'cause you'll break it, and you still can't fix it :D
