16 years agoQuartus 9.1 SP2 WARNING!!!!!
I've opened up an SR for this, but in the meantime, don't install SP2 if you need to use the flash programmer to program an EPCS with or without NIOS. This was specifically on a cyclone II, but it pr...
16 years agoHere we go again!
With 9.1 SP2 the EPCS flash memory won't indeed boot after programmed from NIOS 9.1 IDE. This was fixed in 9.1 SP1 (and 9.1 with patch 0.63) but it looks like Altera has messed things up again and broken 9.1 SP2 ... So I also recommend to remain in 9.1 SP1 ... Jari
