16 years agoQuartus 9.1 SP2 Fails to start
Hello, When I try to launch Quartus 9.1 sp2, I get the following error message: quartus: error while loading shared libraries: /opt/altera9.1sp2/quartus/linux/libccl_err.so: cannot restore...
15 years agoUnfortunately, the solution proposed is not the correct one, as SELinux is being completely disabled...
The correct solution to the problem requires Altera to rebuild the dynamic libraries without text relocations. This is normally achieved by compiling them with the "-fPIC" option (if using the gcc compiler). Further information on the issue can be found at akkadia <dot> org <slash> drepper <slash> textrelocs.html By all means this is a bug in the binaries distributed by Altera and only Altera can resolve the issue. Any idea on how to forward the issue directly to Technical Support ?
