19 years agoQuartus 61 jtagconfig pb
Hello, I uninstalled Quartus 5, I erased the directories, then install Quartus 61. Since then when pluging my 1c12 board I got an error with jtagconfig.exe. it writes: 1) Nios II Evaluation ...
19 years agoI have a similar problem where jtagconfig gives an exception, but will continue.
Then when downloading the image nios2-dbg-server will lockup after the download, even from command line. terminating the process allows me to continue and i can eventually debug the code on the cyclone ii dev board. with the same software / hardware on my desktop machine everything works fine. I've tried disabling all software / firewalls /virus scan etc on the laptop with no success.
