19 years agoQuartus 61 jtagconfig pb
Hello, I uninstalled Quartus 5, I erased the directories, then install Quartus 61. Since then when pluging my 1c12 board I got an error with jtagconfig.exe. it writes: 1) Nios II Evaluation ...
19 years ago --- Quote Start --- originally posted by iztok.jeras@Dec 11 2006, 10:07 AM does flash programming from nios ide work ok for you? i get an error, probably a java gui related problem.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=19946)
--- quote end ---
--- Quote End --- I also had problems with the flash programmer in NIOS 6.1 IDE and I reported it to Altera. There's a bug in flash programmer, which will be fixed into NIOS 7.0. The workaround for me was to add a "short" name into the board name in SOPC. I.e. the board name should be like "Full name (Short)". I had only "Full name" and Flash Progammer gave an error when trying to create a new lauch configuration. Jari
