20 years agoQuartus 5.1 and Nios II IDE 1.1 compatibility
Dear all,
few days ago, I updated ... http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/dry.gif ... my development environment with the following configuration: Quartus / SOPC 5.1 Build 176 (full install) IDE NIOS II 1.1.0 Build 137 (full install) and I meet with several new issues under the NIOS II IDE http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/mad.gif : a. The folder NIOS II device drivers folder doesn't appear any more, b. If I compile the Web server application example within the 2S60 standard design example, the alt_sys_init.c file, automatically generated, doesn't refer any more to the device driver's declaration and initialization macro (x_INSTANCE and x_INIT) as the lan91c111, etc. What's wrong ? Any help is welcome ... Gaël3 Replies
--- Quote Start --- originally posted by maceg@Nov 22 2005, 05:04 PM quartus / sopc 5.1 build 176 (full install)ide nios ii 1.1.0 build 137 (full install)
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=11085)
--- quote end ---
--- Quote End --- I think that probably Nios II and Quartus II versions should go together... that is... you should use the 5.1 version both for Nios II and for Quartus II... bye Paolo
I use Nios II Integrated Development Environment
Version: 1.1.0 Build: 137 And quartus 5.0 No problems on the stratix II board. Still can't programm the Cyclone II http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif - Altera_Forum
--- Quote Start --- originally posted by fire@Dec 1 2005, 10:37 AM i use nios ii integrated development environmentversion: 1.1.0
build: 137
and quartus 5.0
no problems on the stratix ii board.
still can't programm the cyclone ii http://forum.niosforum.com/work2/style_emoticons/<#emo_dir#>/sad.gif
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=11293)
--- quote end ---
--- Quote End --- Support for Cyclone II was introduced in the Nios II 5.0 release; you should use this version at the minimum. (the Quartus II 5.0/Nios II 5.0 releases occured when Cyclone II chips and development boards became available).
