21 years agoQUARTUS 4.2 NIOS 1.1 UPDATE PROBLEM
After update to Quartus 4.2 and Nios 1.1 I have a problem with an 8-Bit Slave (user logic) the adress lines are connected as follows CPU A 9 8 7 6 5 4 3 2 1 ...
21 years agothe problem still exists, can someone from ALTERA please check what the problem
is, setup of user logic wrong ? physical connection to 8 Bit slave wrong ? IORD, IOWR problem ? conversion problem ? the proposed workaround: multiply the register * 4 before calling IORD and IOWR, results in a multiplication by 16 for __builtin_ldwio ??? (see macro IORD in io.h) what will be a workaround, and what I have to change with next software version ? should I go back to Quartus 4.1 and NIOS 1.0 ???
