19 years agoQuartus & Mandriva
I hope this is an acceptable post on this forum! Apologies if not. Today I installed Quartus 6.1 on Mandriva 2007. After I had installed it (which was pretty straightforward) I went to the bin ...
19 years agoQuartus, on Linux, uses shell scripts to setup the environment from which it tries to run. Take a look at qenv.csh, in the adm directory, for starters.... Where you need to take it, from there, depends greatly on what you can discover by adding debug statements to this script.
It's definitely possible to get Quartus II to function, on unsupported versions of Linux, but it does require some good UNIX/Linux skills. Cheers, - slacker
