19 years agoQuartus & Mandriva
I hope this is an acceptable post on this forum! Apologies if not. Today I installed Quartus 6.1 on Mandriva 2007. After I had installed it (which was pretty straightforward) I went to the bin ...
19 years agoI think there are problems in your license file. Look at the example file in the
http://www.altera.com/literature/manual/quartus_unix.pdf (http://www.altera.com/literature/manual/quartus_unix.pdf) There must be several entries of FEATURE. (around 10 entries in my case). FEATURE quartus alterad FEATURE altera_mainwin_lnx alterad .... Please try get them from Altera again. And don't post them all here, you should give only the beginning of each line if you still have problem.
