16 years agoQT (embedded) on uClinux?
I'm going to build some GUI applications running on uClinux and would like to know if a port of Qt exists for the Nios2 processor? I tested some applications created with FLTK but would like to switch to Qt. Roman3 Replies
If you get the MMU distribution of Linux for NIOS II, there is qt-embedded in the libs directory. I haven't had a chance to try it, so I don't know if it works.
Thank you.
Recently I heard about Qt running on Blackfin. They actually got Qt to run on the mmu-less uClinux system if I'm right. I'm gonna go in for a closer look. Roman - Altera_Forum
Hi Roman,
sorry, i don'know anything about your question, but I would like to ask you something; I even don't know almost nothing on SW developing but I would like to begin, can you tell me if it is possible to devlop sw using Qt and run it on a Nios2 processor that use micrium MicroC/OS-II as OS? thank You john
