13 years agoQsys reset bus and its warnings
Hello guys, I am experiencing an interesting problem, where the Nios CPU, that has been working on Quartus 12.1 now resynthesized on Quartus 13.0sp1 doesn't work. I've also made a QSYS system rege...
12 years agoI have the same problem in 13.1. if I checked the "reset the system" in "run config" tab, the niosII program will not run. as the same reason, when I programmed the sof and elf to the EPCS, the NiosII don't run.
