ASubr1
7 years agoQsys interconnect
I have a Nios II processor system with my own Qsys component which to monitor data memory access. The component has one slave (s1) (Nios data master is connected here) and one master (m1) (slave port...
Ahmed_H_Intel1
7 years agoHi,
Good investigation. Yes disabling hardware interrupts is not a good solution but this narrows down the issue to know the root cause. Did you check the interrupt configuration or use Vectored Interrupt controller VIC instead to see if the same issue exists?
