Qsys interconnect
Hi Arudchutha,
First of all, I see you can count the read/write via NIOS II by adding a PIO component from NIOS Qsys that goes up every write or read command happens, or to use the C-code in NIOS in counting the read/write executions.
One more thing, This might be a cash issue, i think you need to clear the On-Chip memory cash first to be sure that you see the correct count. I am not sure as I didn't see how you constructed your system, please correct me If I understood the issue wrongly.
In the new case you can mention my name while creation and I will be following with you this issue.
- ASubr17 years ago
Hi
Thank you for the response.
Actually my component is doing more using the data memory accesses at real time. For the debugging process I simplified as a simple counter.
I built a simple NiosII system with clk, id, timer, jtag uart, two onchipmemory (one for data memory and one for instruction memory), NiosII/f and counter. Accesses to data memory goes through counter.
NiosII/f settings: Reset vector memory: instruction memory offset:0
Exception vector memory: instruction memory offset:0x20
Instruction cache: 4Kbytes
Data Cache: None
Multiply/shift/Rotate Hardware: Auto selection
Include JTAG Debug
One more thing , now I could reduce those extra accesses from 95 to 9. When I create an application project using NiosII Software Build Tools, some settings I left as default. Now I changed these two to instruction memory : hal.linker.exception_stack_memory_region_name and hal.linker.interrupt_stack_memory_region_name. Now extra accesses are multiplies of 9.
- ASubr17 years ago
Hi
I could find that those unknown data memory accesses are because of Interval Timer interrupt. But I still wonder what hardware interrupt does with data memory even after changing interrupt_stack_memory_region to instruction memory. Anyway I could eliminate those extra accesses by preventing timer interrupt request for a certain portion of my program where I am taking data memory accesses. But disabling hardware interrupts is not a good solution right? What are that read/write to data memory during timer interrupt?
