Qsys interconnect
Thanks for your update. If I understanding it correctly, in your current simple test design, you have NIOs II -> Counter -> On-chip Memory. Just wonder if you have had a chance to signaltap the following during a write only process:
1. write from NIOs
2. write the On-chip Memory
You can then cross check if the write activities are tally. With this method, you could isolate the addressing from the debugging.
Chee Pin
- ASubr17 years ago
Hi
Thank You.
I checked signals of data master port at Nios, counter's slave & master and on-chip-memory's slave port. Yep all are same. Those extra addresses are coming to on-chip-memory.
But still couldn't find what they are.
And another thing, for the same program (even without compiling again), these extra address sometimes come sometimes don't.
