ASubr1
7 years agoQsys interconnect
I have a Nios II processor system with my own Qsys component which to monitor data memory access. The component has one slave (s1) (Nios data master is connected here) and one master (m1) (slave port...
CheepinC_altera
7 years agoHi,
Regarding your inquiry on how Qsys identify the specific slave, as I understand it, in the Qsys system, each component or slave will have a specific base address. Master will use the base address to identify the target slave.
Chee Pin
ASubr1
7 years agoHi
Yes, Each component will have base address.
But when I examine address signal(avs_s1_address), it is byte address. So base address is invisible to us.?
Thank you
