13 years agoQSys doesn't properly create all output files during generation
I'm working with QSys (Quartus II, V13.0) on a NIOS II based design imported from SOPC builder. If I generate the output files for Quartus, not all required files seem to be properly build. (Simulat...
13 years agoHi, that is indeed really strange. Maybe you should post a support request to Altera and tell them about his buggy behavour. I also found some other bugs related to the release 13 of the Nios tools and informed Altera about that.
With the bsp I mean the board support package which you need when building software for your Nios project. That one contains the system.h file when you generate the bsp. Hope this info helps you further! regards
