ZhiqiangLiang
1 year agoqspi driver in NIOS bsp in Cyclone 10
Hi, I am running NIOS II in Cyclone 10 LP 10CL120YF484. The flash I am using is M25P64 which is qspi interface. The problem is that EPCS flash controller is not compatible for Cyclone 10. I am go...
ZhiqiangLiang
1 year agoThank you!
If I convert elf into hex file according to your link, the questions are:
1) how to specify the start flash address of hex data?
2) how does NIOS know the start flash address of hex data?
3) will any component copy hex data from flash to RAM when NIOS boots?
Archer_Altera
1 year agoHi Zhiqiang,
Please refer to below document and go through the description related to EPCS.
