ZhiqiangLiang
1 year agoqspi driver in NIOS bsp in Cyclone 10
Hi, I am running NIOS II in Cyclone 10 LP 10CL120YF484. The flash I am using is M25P64 which is qspi interface. The problem is that EPCS flash controller is not compatible for Cyclone 10. I am go...
ZhiqiangLiang
1 year agoThank you!
I have already read the pdf you mentioned. The picture I pasted is the result when I follow the pdf.
- Archer_Altera1 year ago
Hi Zhiqiang,
Below table shows the minimum component set required. Have you enabled JTAG debug module level1 or greater?
