ZhiqiangLiang
1 year agoqspi driver in NIOS bsp in Cyclone 10
Hi, I am running NIOS II in Cyclone 10 LP 10CL120YF484. The flash I am using is M25P64 which is qspi interface. The problem is that EPCS flash controller is not compatible for Cyclone 10. I am go...
ZhiqiangLiang
1 year agoThank you for your reply!
This question is very critical for my design.
Is there a way by which I can run the GSFI IP on Quartus 18.1?
- Archer_Altera1 year ago
Hi Zhiqiang,
I look at quartus 18.1std tool, it has GSFI IP too. Please try it.
The example design in quick start guide document is created in quartus 18.1std.1. So quartus 18.1std.1 should be OK to use this IP.
Cyclone® V FPGA – Generic Serial Flash Interface and Nios® II Processor Booting Design Example
If you are OK to upgrade to 18.1std.1 version, you may go to Intel® Quartus® Prime Standard Edition Design Software Version 18.1 for Windows and download update 1 setup package shown as below.
Hope this is helpful.
