Q^6.1 Fitter dies
Has anybody else noticed that Q6.1 Fitter dies at 96% and the only thing that will continue is the time counter ? dual cpu load is at about 1-2% ... idle.
the last messages within the processing window are : Info : Fitter routing operations ending Info : The fitter performed an Auto Fit .... Info : Started post-fitting delay anotation Warning : Found .... output pins without output pin load capacitance assignment shuting down q6.1 and restart and q6.1 will compile fine ..... This happend now and then ... but not very often. Michael PS: Q6.1 need about 2/3 of the full compile time than Q6.0 with 2 cpu cores. Thanks Altera9 Replies
I too was seeing this on a dual core machine. I haven't been able to reproduce it in a while to figure out what is causing it.
Can you please email a brief system description of your system (processor, memory, and OS). - Altera_Forum
Shure.
It is a Dell Optiplex GX620 (it is a very silent but incredible fast system) P4 HT 670 Prescott 3.80GHz FSB800 Family F Model 4 Stepping 3 L1 16KB L2 2MB Cache MainBoard is a Dell Model 0F8096 with a i945G/GZ Rev A2 Chipset and a 82801GB ICH/ Southbridge Memory is 3GB DDR2 (Dell Default) Video is a ATI Radeon X600 Dual All drivers are up2date. The OS is a Windows XP with the lastest SP installed. Regards. Michael - Altera_Forum
Thanks for the information. If I learn anything new about this one I'll post it in here.
just some more comments about it.
this behavioral of a dieing Q6.1 is not related to a specific design. it happens here will ALL designs. it happens every now and then. but always at 96%. but i haven't seen it if i set the number of cores to 1. we have another P4 server with HT or real dual core (not shure at the moment). today i will start some complete compiles there and see if it happens there too. - Altera_Forum
With MaxII designs, it happens that Q6.1 reports at 81% of the Fitter :
Internal Error: Sub-system: FMAIN, File: /quartus/fitter/fmain/fmain_location_constraint.cpp, Line: 3024 m_soft_locked_constraint.check_constraint( other_constraint->m_soft_locked_constraint) Stack Trace: 0xA5CD : FITCC_CLOCK_REGION_CHECKER::set_oterm_alias + 0x26D6 (FITTER_FITCC) 0xC2DB : FITCC_CLOCK_REGION_CHECKER::clear_usage_for_all_oterms_on_atom + 0xE28 (FITTER_FITCC) 0x18DDA : FITCC_DESIGN::are_atom_location_constraints_mergeable + 0x132 (FITTER_FITCC) 0x1579A : fygr_execute + 0x1655 (fitter_fygr) 0x16FE2 : fygr_execute + 0x2E9D (fitter_fygr) 0xC57E1 : FYGR_TEMPLATE_REGISTER_PACKING_OP::find_shared_input_lonely_register_matings + 0x206 (fitter_fygr) End-trace Quartus II Version 6.1 Build 201 11/27/2006 SJ Full Version Intresting that MaxII freezes at 81% .... if it freezes. - Altera_Forum
are there any new experiences regarding this topic - is there a way to avoid this fitter locking ?
(it just happened three times in a row now ...) thanks Klaus - Altera_Forum
Hi Stonie,
there is currently only one solution known to me ... just set max number of processors allowed back to 1. But most of the time the fitter runs fine with more than 1. So if your fitter dies too, just set this setting back to 1 re-run the fitter and after a successfull job, set it back und run with all processors you have. 2 processors saves about 30% of the overall fitting time here. - Altera_Forum
I also have this issue, thanks for the workaround, my system specs.
Intel E660 2 Gig DDR2 6400 Gigabyte 965P-DS3 Nvidia 7600GT windows xp sp2 with all updates. Thanks, Richard - Altera_Forum
This week i had asked mysupport if a fix for this problem is available bevor the next service pack. As i had noticed this beginning of december and thought that now 2 months later a fix could be available.
but this is the answer of mysupport : "Unfortunately, we don’t have such a fix since we didn’t receive similar issue report before." http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/blink.gif Does this mean nobody has reported this to mysupport ? Well i havn't. But does mysupport not read this forum ? I hope Altera is aware of this issue and has a fix that will be available soon.
