21 years agoProgrmming the EPCS device
Hi NIOS users / experts, Our application has to update the content of EPCS device (both FPGA and application codes) dynamically. Therefore I am looking for documentation about how we can u...
21 years agoThank you Maga , again.
However (as mentioned in an ealier message), there are at least three flash files: epcs.flash, epcs_controller_boot_rom.flash ext_flash.flash. In the past (som ten years ago) I did work with S-records. So interpretin the S-records will not be the problem (I hope). The big questions are: 1. Which file do I need to use? 2. Should I just erae and write all of the data in the flash file onto the flash device? Regards, Kwok Wong
