21 years agoProgramming problems
Hello, I have an altera cyclone (1c20) Nios-II dev board, and am attempting to get uclinux up and running. However, I'm running into an odd problem when trying to upload... I always g...
21 years agoAfter several hours of repetedly attempting to flash various files different ways, finally some progress, but still not quite there.
<div class='quotetop'>QUOTE </div> --- Quote Start --- ------------------------------------------------ Microtronix Linux Extensions Version 1.3, Built December 30th, 2004 ------------------------------------------------ Feb 21, 2005 12:59:31 AM - (INFO) nios2-flash-programmer: Launching Quartus Prog rammer to download: c:/altera/kits/nios2/components/altera_nios_dev_board_cyclone_1c20/system/a ltera_nios_dev_board_cyclone_1c20.sof Pre-Reading 1726KBytes of data from U5: |----.----+----.----| ********************* (18.813 sec). Erasing 27 Sectors: |----.----+----.----| ********************* (31.703 sec). Writing 1728KBytes : |----.----+----.----| *Unable to send write-packet @49152 buffer-chunk write failed @49152 erase-block write failed @49152 write failed @0 Feb 21, 2005 1:00:37 AM - (SEVERE) nios2-flash-programmer: Unable to write to fl ash Feb 21, 2005 1:00:37 AM - (SEVERE) nios2-flash-programmer: Error: Write-operatio n failed on device. - exiting.[/b] --- Quote End --- I'm starting to suspect a bad usb-blaster, but I could be wrong. --Nate
