12 years agoProgramming NIOSII interfaced with custom component, using Avalon MM Interface
Hello Everyone, I am trying to interface NIOS II with a custom component using Avalon MM Inferface where NIOS acts as Master. During the C coding, how do i get access to the function to send/...
11 years ago --- Quote Start --- Hi, I succeeded in implementing the system on board. My custom component is a 128 tap FIR filter which is to be started by NIOS and stimuli is also provided by nios. I made the custom component in Qsys and implemented the system. Now i am able to write the c code successfully on the NIOS without any tool errors. But, i am not able to communicate properly. Below is my code: int var =1234; IOWR(20496,0,11); printf("%d\n",var); //prints 1234 var = IORD(20496,0); printf("%d\n",var); // prints 0 When I am reading the same address and offset, it gives 0. --- Quote End --- HI, I'm currently facing the issues as mentioned in the quote above. May I know the way you resolve it? Thanks HY
