12 years agoProgramming NIOSII interfaced with custom component, using Avalon MM Interface
Hello Everyone, I am trying to interface NIOS II with a custom component using Avalon MM Inferface where NIOS acts as Master. During the C coding, how do i get access to the function to send/...
12 years agoHi, the code look like:
always @(posedge csi_clk or posedge rsi_reset_n) begin // To read if (rsi_reset_n) begin end else if (avs_s0_read) begin avs_s0_readdata = START; end else begin avs_s0_readdata = 0; end end always @(posedge csi_clk or posedge rsi_reset_n) begin // To write if (rsi_reset_n) begin START <= 0; DATA <= 0; end else if (avs_s0_write) begin case (avs_s0_address) 2'b00 : begin// START <= avs_s0_writedata; end 2'b01 : begin DATA <= avs_s0_writedata; end default : begin DATA <= 0; end endcase end end In my C ode, i am trying to write START register (as posted previously) and read back START register. Please suggest. I need to come out of this issue soon
