12 years agoProgramming NIOSII interfaced with custom component, using Avalon MM Interface
Hello Everyone, I am trying to interface NIOS II with a custom component using Avalon MM Inferface where NIOS acts as Master. During the C coding, how do i get access to the function to send/...
12 years agoI have one more question...
I made a new component in Qsys to implement my custom design. And from there i got the base address allocated to that component that will be used during the communication through the avalon MM interface (in NIOS). But I got one more option to implement the custom component.. I created the design in Qsys w/o custom component. Got that design imported in quartus and manually instantiated the HDL file of custom component in the TOP Level file generated by Qsys. I was successful in compiling the code. "But how to get the base address allocated to my custom block in this case ?? I need that address while coding in NIOS."
