12 years agoProgramming NIOSII interfaced with custom component, using Avalon MM Interface
Hello Everyone, I am trying to interface NIOS II with a custom component using Avalon MM Inferface where NIOS acts as Master. During the C coding, how do i get access to the function to send/...
12 years agoDo you mean to include a DMA block in between Master & Slave ??
As per the forum discussions, it suggests to optimize the code to avoid parallel computing. But i cannot understand which part of my design is creating this issue and what should i optimize? Is this the data bus width i.e. 16 bit that i am sending in parallel?? And i did not use Avalon Bridge in the interface.. Is it recommended? I saw in the online lectures that it is necessary but i compiled my code without that too.
