22 years agoProgramming EPCS via NiosII IDE
I have a custom NiosII Cyclone board with both a JTAG header and an EPCS header (active serial). I have been using the Quartus programmer utility to update my single EPCS device with the project .pof...
22 years agoHas anyone successfully programmed an epcs active serial device using the flash programmer utility in Eclipse?
I have tried a few things, but have not gotten any further. The flash does program, but then I get the error "no rule to make EPCSimage", where EPCSimage is the hw image name for my asmi module (as defined in the flash programmer project). My application sof & pof are already made, so what further steps are needed? Do I need to manually edit the makefile to add a rule for making this hw image? If so, what should the rule do? thanks
