19 years agoProgramming Board Flash
I am working on a project trying to develop some software on an Altera DE1 board. It is driven by a Cyclone II EP2C20F484C7 and first of all the SOPC Builder in Quartus II doesn't have a Board Description file for this board. However, that is not the main issue of this post, although it might be contributing to the problem.
The problem is that when we try to program the .sof file to our board via the Flash programmer in Nios II the following error message is produced in the build window # Error - Unable to locate a flash memory module name '' in the SOPC Builder system C:/altera/61/ip/sopc_builder_ip/altera_avalon_adapter_downstream_pipeline/class.ptf We are wondering if this could be a result of not having a board description file for our board. We built our system in SOPC Builder as a "Custom" board and only specified that it was a Cyclone II. We put all the components into the system builder however I've read a couple places that if your using an altera nios dev board you must have a board description file specified. The CD that came with our board contained no such file and the closest description file available in SOPC Builder is for a Cyclone II EP2C35 device and again, not sure if that would be compatible since it's not technically our device. If we have to make a board description file than ANY info on how to generate or find a netlist for our board would be great! Any and all initial comments/thoughts/solutions to this problem are very welcome as anything you have to say may help my team and I try and figure this thing out thanks in advance!
