13 years agoProgramming Altera CycloneV Active Serial x4 - Spansion FL256SAIF00 Problem
Hi, I'm trying to interface a Spansion FL256SAIF00 to a CycloneV FPGA using active serial x4 mode has anyone had success using a Spansion QSPI device for programming an Altera FPGA? A Micron 25...
13 years agoSo I sent spansion a question about this and here is their response:
4-Byte addressing support is required to configure FPGAs from 256Mb or higher density SPI Flash. Altera requires specific operations to enter (4BYTEADDREN – B7 Command) and exit (4BYTEADDREX – E9 Command) 4-Byte addressing mode. Our S25FL256S does not support “B7” and “E9” commands, thus CANNOT be used to configure Altera FPGAs in Active Serial configuration mode. Hope it helps.
