21 years agoprogramatically set the PC
Hello, I have a system with a 1s10 and Nios II with an exception address pointing to an internal Boot Monitor ROM. I have built (in SOPC builder) into the Boot ROM a .c file which turns on som...
21 years agoThanks for the tip. I'll try it this morning sometime and I'll let you know...
Of course it will be hard for me to tell if it works because I'm having a problem running out of external flash. When I program external flash with my program (via the Flash Programmer in the N2 IDE which reports success) and set the reset vector to external flash in SOPC builder - nothing happens on reset or power up, the program doesn't run. Yet I can run from external RAM no problem. Any ideas on that one? thanks again!
