21 years agoProgram UBoot
Hi all,
A couple of questions that people might be able to help me out with. There seems to be a common issue with setting up the initial boot sequence for a NIOS boot loader and whilst there is a lot of information out there I seem to be going around in circles at the moment. Here is what I'm after. I have the following system: Flash, 0x00000000 to 0x007FFFFF (i.e. 8Mb worth) SDRAM, 0x01000000 to 0x01FFFFFF (i.e. 16Mb worth) EPCS mapped in as EPCS controller peripheral at location 0x00810800 NIOS II f core with flash/tri-state bridge and EPCS controller Reset address is set to the EPCS controller base address Exception address is set to 0x0100020 (i.e. into SDRAM) Now I want to put the configuration data (.sof) into the EPCS with a UBoot on top of it so that at boot up U-Boot will fire up from the EPCS, it (U-Boot) will then load an elf executable from the flash into sdram and execute it at a later point. When I boot up my current system I have succeeded in getting U-boot to be placed in the FLASH but not into the EPCS, in this arrangement it comes up correctly and the EPCS boot loader correctly loads u-boot out of flash and executes it. The problem I am having is getting all the parameters correct for scripting all of this so that I can get U-boot to come out of the epcs, can anyone suggest the correct steps to take (in script) to make the build happen, obviously I want to automate the, but it is being troublesome getting the correct parameters, also the quartus_pgm utility doesn't like running from within cygwin so this means having to shell out to win32 cmd to execute that, again anyway way around this? Regards, DW21 Replies
Ahh thanks Scott, I'd skipped the -O linux on my attempts so the inconsiderate little b***ard was ignoring me during bootup. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/wink.gif
