21 years agoProgram UBoot
Hi all, A couple of questions that people might be able to help me out with. There seems to be a common issue with setting up the initial boot sequence for a NIOS boot loader and whilst there i...
21 years ago> What parameters should be used for mkimage to generate the correct type
> of img file for uboot to load and execute assuming these specified addresses? Assuming your application entry point is the at the start of your uncompressed binary image: $ mkimage -A nios2 -O linux -T kernel -C none -a 0x01000000 -e 0x01000000 -n "MyApp v0.1 2005-02-22" -d MyApp.bin MyApp.img Basically, you're just telling u-boot that your image is a linux kernel -- that fact that it's not really a kernel doesn't matter. When bootm is executed it will copy the image data to the load address then jump to the entry point after disabling interrupts (and a few other things). If you want to use compression, you can compress your binary file using gzip: $ gzip -c MyApp.bin >> MyApp.gz Then use "-C gzip" with mkimage and the compressed file (-d MyApp.gz). bootm will then decompress as it copies from flash. Regards, --Scott
