21 years agoProgram UBoot
Hi all, A couple of questions that people might be able to help me out with. There seems to be a common issue with setting up the initial boot sequence for a NIOS boot loader and whilst there i...
21 years agoHi Rajendra,
If you're using Nios, you can simply download u-boot from: http://www.sourceforge.net/projects/u-boot (http://www.sourceforge.net/projects/u-boot) then follow the directions in doc/README.dk1sxx. For Nios-II the source at: http://www.psyent.com/download (http://www.psyent.com/download) is the best bet. Build u-boot for the PK1C20 board: $ make distclean $ make PK1C20_config $ make You will need to edit include/configs/PK1C20.h to match you hardware configuration. Regards, --Scott
