21 years agoProgram UBoot
Hi all, A couple of questions that people might be able to help me out with. There seems to be a common issue with setting up the initial boot sequence for a NIOS boot loader and whilst there i...
21 years agoHi DW,
> Now I want to put the configuration data (.sof) into the EPCS with a > UBoot on top of it so that at boot up U-Boot will fire up from the EPCS ... snip ... > can anyone suggest the correct steps to take (in script) to make the > build happen 1. create the u-boot flash file with elf2flash and these parameters: --epcs --base=0x0 --end=0x7fffffff --flash=<the epcs chip designator> --input=u-boot --outfile=u-boot.flash --boot=<path to epcs bootloader srec> The bootloader srec is in the {install}/altera/kits/nios2/components/altera_nios2/boot_loader_epcs.srec 2. download u-boot to the epcs device. $ nios2-flash-programmer --epcs --input=u-boot.flash --sof=<path to pgm sof> 3. create the configuration flash file. $ sof2flash --epcs --input=<path to your system sof> --ofset=0x0 --output=config.flash 4. download the configuration flash file to the epcs device. $ nios2-flash-programmer --epcs --input=config.flash --sof=<path to pgm sof> --relocate Don't forget the "--relocate -- it's important ;-) ... and you should be good-to-go at this point. Hope this helps. Regards, --Scott
