15 years agoProgram storage
I am designing a system that will have time-critical and non-time-critical instruction. I want to store all the time-critical instruction and data in on-chip RAM and the other in external SDRAM. How ...
15 years agoSpaugh,
The Nios II application program is going to be too big for on-chip memory since I have used a lot of M9K blocks for a lot of the hw modules. I want to be able to put some C functions that will be doing critical time function on some allocated on chip memory. pragma seem to be a good way to separate such functions but I am not aware of any Nios docs that describe how to accomplish this with pragma. If you do, I will appreciate the ref. By the way, I am using Nios II SBT design flow. Thanks a lot
