16 years agoProgram runs in loop
I have written a program that writes to the user through nios 2 console (jtag uart) and takes user input as well. However, the program does not pause to accept user input. Instead it continues to run...
16 years agoYes i tried using the read() function which doesnt seem to pause. I will try accessing the UART directly but if you could explain a little why those masks are used in the code snippet I think I could better understand where exactly to access the UART in my code.
Thank you for your help. Chase
